Wtb: Supercharger Kit
im looking to buy a supercharger kit for '96 silverado (350 ci. 5.7L) Z71 4X4. If anyone has some info on new or used stuff hit me up. I have been checking into the magnacharger kit for my truck (no longer being produced) and the vortech kit. I'm looking to find a slightly used setup because the cost of brand new will kick my ass.
I`ll send you a pm of one a guy was trying to get rid of, its a complete whipple for a 350 vortec, might still have it, i belive it was in florida though?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
