Biggest Tire On 17" Rim
I have stock 17" rims on my NBS 2007 Silverado 2wd with leveling kit. I was wondering what the biggest tire I can run.
Its only the width thats the problem. Anything over 12" wide is gonna be a problem. Most 285s are around 11.6", 11.7" so you should be good. Any tire shop will give you the facts.
I found the info i needed for the factory rims.
They are 17" x 7.5" with a 31mm offset.
The fatory tire size that have have is
245/70/17 which relates to a 9.6" width/30.6 height
I am looking at a couple diffet tire sizes.
285/70/17 which relates to 11.2" width/32.8 heigth
285/75/17 11.2" width/33.9 heigth
or
295/70/17 which relates to 11.6" width/33.3" heigth
295/75/17 11.6" width/34.4" heigth
i have a rough country leveling kit on and i am looking to fill in the wheel wells more. I am going to go with an AT tire either bridgestone, Nitts or cooper not sure yet. i know thw ones with the 70 rating will give me a litte wider tire.
I am looking for opinions on which one you would go with.
Thanks,
I have a 2" RC level on mine with BFG AT 285/70/17. I wouldn't go any bigger than that. This size tires fills the wheel well very well, any bigger and your probably looking at some trimming. Plus the stock wheel is only 7.5" wide. I believe that 285 is the max for that size wheel.
I would stick with the 285/70/17 tires with the RC 2" kit. See pic below and you will see how it looks.
Yeah, ditto to the above. Anything larger than a 285/70 will have low milage and wear wierd on the stock rim.
Do you have any side veiw of your truck to see how well the tirs fill the wheel well.
Thanks,
I have Goodyear wrangler duratracs 285/70/R17. They look amazing and I barely have room in the front with wheels turned all the way. I also have the Rough Country 2" leveling kit. It looks great I will get pics up in the morning as soon as I wake up.
here is a side view for you. This is the best I could find that I have on my computer at the moment. This is when I first put them on.
Food for thought. 285/70/17 is a very common size, and I've found that most tire shops stock a variety of brands in this size, or can get them within one day. Something to think about.
Get a wierd size, get a flat tire, the odds of finding a replacement in a short amount of time go way down.
Thank you that is a good pic. They do fill it on good.
  • 1 month later...
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
