What I Really Want To Know Is...
Grebbler
...where are all my socks going?!
I have purchased easily 10 packs of socks last year. That makes my
official sock inventory about 60 pairs not counting the previous years
stock. And yet, come laundry time, I can only find about eight pairs
(even after looking under the bed and sofa cushions).
Could it be true that they are hanging out in an alternate dimension
along with my Bic lighters and pens? Is there some kind of 'exchange
program' going on that if a lighter turns up, another pair or two of
socks have jumped the fence to freedom? Are the lighters conspiring
against me and running an underground railroad or are they merely
lookouts assisting my oppressed apparel in their bid for a better life?
Are some of them going off on long vacations while a few stick around
to allay my suspicions?
*** takes medication to curb images of socks lounging around a beach
under a warm sun, sipping on comical fruit drinks with little umbrellas
in them.***
In the past I have taken a relaxed approach to this dilemma. I would
simply write them off as dryer lint and go get some more that look just
like them. That could be the problem - since they are alike I cannot
spot when a subversive sock has come back and is even right now hidden
away in the drawer spreading dissension among the ranks.
I am at my wits end!
I am currently tagging each one with a number and an RFID locator.
Each sock will be checked off on the master roster as they go into the
washer and back in when (if) they come out of the dryer!
I'll teach those fuzzy tubes of smugness who's the BOSS around here!!!
** takes deep breath **
If anyone can shed some light on the matter I would be grateful.
Ed
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
