1/4 mile times
Bill89
I ran the 1/4 in 14.5@95mph. See my sig. for the details of my truck. For my setup, I think its pretty good. I think my maximum rpm was 7500. It was severely loud. My exhaust system is true duals. Its 2 1/4" with strieght flo-thru 20" glass packs with no cats and Hooker Headers. I'm using 4.11's with a Detroit in the rear. My TH350 has a stock stall converter with a stage 1 shift kit. I ran with 31" BFG A/Ts front and rear. I usually have 33" TSLs on the back tho.
Kyle
Thats really good! Nice setup btw.
Have any pics? You should submit them for truck of the bi-week!
If I submit some pics of my dad's truck to truck of the week over at PUTC would they make it?
1999 F-350, Red, 4x4, PSD, 6 speed,
NVG 272, Crew Cab, 4.88:1, Front and
Rear Ranch Hand Bumpers, Ramsey
10,000lb Winch, Black head ache rack
with matching tool box.
Kyle
You need to get rid of that stock stall.  You at least need a 2500 stall.  It will make a difference.  I use a 4500 stall but I don't stall it all the way.  At least not at this time.
I think if your motor has all that in it, you should be able to pull a little better times than that.  I have a 350 with 10.5:1 pistons, mildly ported steel GM heads with a daul plane intake and holley 750.  Then I have a turbo 350 trans, two piece drive shaft and 3.08 gears with an open diff.  I ran a 14.10 and not hitting full throttle for a while because of tire spin.   I plan on putting 3:73's in and I just got a locker for it and hopefully hitting mid 13's this summer.  Theres more stats on my engine on my site.
Seems like you can get a low 14 with your setup.  With a loose converter, you should be good for high 13s.  My buddy can pull my Camaro which does around 13.6, but he's running a 4x4 big block '68.
My best run so far [email protected] mph.  1973 chevy c/10, but alot more to go. Need a stepper gear, better tires, re-jet the carb, etc.  The high 3.07 open gear was keeping my rpm from coming up past 5200 with the stall i got.  Specs
1962 327, punched .030'' over, total compression on built engine 9.78:1, ported and polished 1965 double hump heads, manley 1.94/1.60'' valves, crane powermax dual. patt cam 272/284 with .454/.480'' lift, 1.6 ratio roller rockers (brings lift to .484/.512''), edelbrock performener intake and 600 cfm carb, Th-400 trans, B&M shift kit, GER 2,800 rpm stall converter, Flowtech headers, 2.5'' dual pipes, flowmaster 2 chamber mufflers, Cheap street tires 29.06'' tall
Kyle
Not sure, but you should submit your truck here!
327Chev, you did not say where you lived? If you did I missed it.  That time might be good if you live in Denver or some other place that is at elevations.  But if you live on the coast somewhere they are a little slow.  With a small block, on gas and a carb the best help would be a stall converter, you might want to check with a transmission shop a few years ago some people were using what they called a switch pitch conveter that has a electrical hook up that would alow the stall and lock up of the converter to be changed.  I know that in some street set ups it really made a big difference in their times on the strip, and did not hurt them driving on the street.
    overspeed
    overspeed
  • Who's Online   0 Members, 0 Anonymous, 220 Guests (See full list)
