#12 team done
General Lee 01
That really sucks.  I was hoping Mike would run that car next year.  He did pretty dang good with it the last part of the season.  I guess Penske doesn't want to fit the bill for three cars.  Can't blame them much, but at the same time you gotta wonder why he would give up that sponsor and a team that is capapble of winning.  Oh well.  I hope Mike made a good enough impression that he gets a ride with somebody, I just hate to see him back in a second rate ride again.  I think if he's with a good team he can win a race or two.
Update-Williams PR said that Exxon/Mobil will move to an associate sponsor on the #2 and #02. So Penske is gonna get their sponsorship money anyway.
I can't say that I'm completely suprised by this, but after the way the 12 car ran the last part of the year I figured they might go ahead and keep it around.  But I guess they figured that they would have enough work making cars for Rusty and Ryan, and decided to axe the 12 car.
I'm a big Penske fan. He won the Indy (IRL) 500 again, won the Cart championship. But I wasn't a fan of Penske when he fired Mayfield, or for firing Mike Wallace.
But...looks to me like sweet revenge for Mayfield with Evernham. Maybe he gets the #12 back afterall??
Well, I'm a Penske fan.  And I didn't like Mayfield alot, so I was glad when he fired him.  I didn't see a problem with it, when I thought he would keep the team going, I saw it as an opportunity to get a jump start on next seaon with a new driver.  But if he was gonna axe the team anyway, he should've let Mayfield keep his job for the rest of the season.  That would've been the right thing to do I suppose.  But I am glad that Mike got a shot in a good car, maybe that showing will give him a chance in a decent car for next year.
If I were Mike Wallace, I'd be one pissed off pony. To run so good with the (I dare say) best team he's had in his career and  hear that the team is shutting down, that has to be hard.
Quadrunner, Jeremy Mayfield will be in the #19 regardless of what happens w/ Penske.
I used to really like the Penske team, Rick Mears era, but lately you know it's all about money and Penske can get the sponsers.  A few years before the IRL and CART split it got kind of boring, cause they always won.  Then when they split he went where he thought he could be in control.  I've always liked the underdog also.  Liked when Michael Waltrip won this year, finally.  But racing is all about money and sponsorship not necessarily talent.  A lot of taleneted drivers out there the racing leagues just have to keep on top of keeping it competitive and the costs under control.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
