Bobby Labonte
sincityZ71
Well, very unexpected, but I go to talk on the phone to Bobby Labonte today.  He is here in Vegas testing at the speedway.  A lady who works at the office has a "friend" who works out at the track.  He was eating lunch with Bobby and a few other drivers and was taking to her on the phone, so she just hands the phone to me and says it is Bobby Labonte.  I was like...ah....hi....ah....how's it going????  Was totally unprepared for that conversation, so I sounded like an idiot.  Oh well, the guy also took a pic of Bobby talking to me on the phone and Bobby is going to sign it for me which is cool, may even get a chance to meet him when he is back out here in March for the race.  Oh yeah, if you didn't know, Bobby Labonte is my fav driver.  I missed out on talking to Tony Stewart, Schrader, and some others though.  Anyways, that was the highlight of my day, and probably my week (have no life  :D )
Have a life or not, that would still be a highlight.
If you talk to any of them when they come back, I would like to know what Schrader is like.  He seems like he would be a really nice, fun guy.
Schrader is a very nice guy. He owns a race tack about 30 minutes from where I live and he visits it frequently during the year. When he comes to town, he always has a couple buddies along. Last year he made quite a few appearances. He brought down, Dale Jr., Tony Stewart, Bobby Labonte, and a couple others, just to name a few. He races modified class and Tony comes with him when the owtlaws are running.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
