Silver Birch/pewter
OK how about all those Silver Birch/Pewter trucks out there, show us some pics.
If there are any.
I like the color. Here is a pic of a couple we have owned and since sold. The first was my wife's '03 Denali and the second is a pic of my '02 Silverado (still miss that truck).
Wife's '03 Denali
02 Silverado
I'll chime in with mine!
Laterz
Stanz
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
