Transfer Case Fluid?
2005 Suburban 1500
I am going to change my transmission fluid and will also change the transfer case fluid.
I am using Dexron VI in the tranney , is it Ok to use the same in the T-case?
I just picked up 2 quarts AutoTracII from the dealer for about $9/ea, like Alaska said, if you have the Auto Push-Button 4 wheel drive.
Auto Trac 2 Fluid in the case, if you have the auto
What is Auto Trac 2 ????
It's the name of GM's fluid for the auto transfer case.
Is there an aftermarket product.....can you only buy it at the dealership?
Not that I have found. As stated above, you only need 2 quarts. You will have to get it at the dealer.
