Buying A High Mile'er...
Hey guys,
As some of you may know, I'm in a search for a truck. I just found a 2000 GMC Z71 with about 230 000 miles on it (370 000 km's). Body looks excellent. In your opinion, would it be worth buying a cheaper truck like this, running the engine until it dies and then stick in a newer 5.3L (and possibly tranny)? Or is this going to be too much hassle and more money than if I were to shell out another $7000-8000 and buy say a 2005 Z71 right off the bat with low mileage?
By the way, do the 2000's have 4 doors, or are they like the 99's with only the 3 doors?
Thanks!!
The later model 2000's have 4 full doors. Jan 2000 they became an option and in April (when I ordered mine) it was standard
A friend of mine has a 01 with 3 doors. I always thought it was 02 when they became standard.
April 2000 they discontinued the 3rd door and went standard with 4 doors, I know because when I ordered mine this was all that was available. How does he have an 01 with 3 doors, that makes no sense?
Prove it!
:( no seriously, I believe that the ordering guide dropped them back in 2000...
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
