Abs Light - 02 Silverado
Smitty00Z71
Got the ABS light on. Codes read the following...
C0221
222
223
225
226
227
all these code point to the left and right side speed sensor.
C0265 - EBCM relay circuit
C0281 - Brake switch circuit.
Now, i had a wheel bearing go bad a few weeks ago. We changed the wheel bearing and then soon realized we changed the wrong one. No problem, we took the old wheel bearing and installed it on the other side, problem fixed...case closed
the ABS didn't show up until a few weeks later. I really dont think the speed sensors are the issue.. I think maybe something came loose. The day the problem started, I did drive down a real real bumping dirt road. Maybe something is loose now? I checked the speed sensors, all seem good and tight. I also cleaned the ground under the drivers door.
any new idea's ???????? Can the EBCM code cause the other codes? or vi versa?
It would be helpful to always include your year/model vehicle in the first post. Some people have factory service manuals here for a few years and might be able to look something up for you (if we know the year/model).
Then with some year vehicles, there will be just rear wheel ABS or 4 wheel ABS. The diagnostic codes would be different depending on the ABS in the vehicle.
Other than that, as mentioned on another thread by someone, you can get your ABS rebuilt. These ABS have electronic circuit boards in them with a bunch of solder connections. These connections can come loose. Here again is the link for that...
http://www.modulemaster.com/en/index.php
Then the electrical connectors from the wiring harness to the ABS are usually pretty darn solid, but might want to examine it to be sure the electrical connections look clean and that they would be making good electrical contact.
But it seems to me with so many different trouble codes, all these things would not go out at one time. I would think it would be a loose electrical connector or the ABS control unit needs to be rebuilt.
2002 Silverado as stated in the subject line. thanks
Smitty,
Check all the wires going to the EBCM itself.
Check the wires under the dash going to the brake switch.
Do your brake lights still work?
I doubt it...
Something could have come loose after driving down the rough road.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
