Peta Mad Over The Swatting Of A Fly
Silverado4x4
I agree with the Peta dude. What did that fly do so wrong to deserve being brutally murdered? :thumbs:
Dont they take a crap every time they land? What would you do if someone came up to you and took a crap on your arm.... thank them and tell them to have a nice day?
No, but I wouldn't murder them in cold blood either. :mad:
:mad:
I agree with the Peta dude. What did that fly do so wrong to deserve being brutally murdered? :mad:
:mad:
:thumbs:
First time I saw that on TV, I knew someone would have something to say about it. :thumbs:
with the swat of the Presidents Hand , a Fly and PETA's credibility both died ...
what next - worms for fishing ,,, " NO the Tape worm in your stomach has rights too "
It is a nasty insect, that got in the way. :mad:
DIE, fly. :mad:
DIE, fly. :lol:
:thumbs:
Peta, is just one of many organizations that are wrong in this country. It was a fwonking fly, kill the summabitch. :thumbs:
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
