Electric Fans
So I'm chugging up a pretty severe 4WD road in 4LO. The coolant temp was up to 225 degrees, and the tranny temp was up to 218 degrees. The electric fan for the radiator never came on. When are they supposed too?
I think the fans start to spin up at around 160... then full speed around 180-190. If you have them, you could have the temps lowered if necessary by a custom tune. I think those temps are a little high. I've never seen mine over 210 on the gauge and never over 180 on the trans. :lol:
If your still in warranty, I'd take it in.
On older vehicles the fan should turn on when the *computer* coolant temperature sensor is above 225 deg. F. Or when the A/C is on and the high pressure side reaches a certain pressure.
For your vehicle, this information would be in a GM factory service manual for your year/model vehicle.
And probably you would just test the computer's coolant temperature sensor to be sure it was giving the correct reading for various temperatures. This tells the computer what temperature the engine is. Then the computer decides when to turn on the fan.
Also you would want to check fuses. This information would be in your owner's manual. Here is how to check fuses...
http://www.dinosaurelectronics.com/Test_Fuse.htm
Then there is probably a relay for the fan and this would be computer controlled. A GM dealer could hook up an electronic tester and tell the computer to turn on the fan. Then you could see if the relay and fan were working when the computer told it to turn on. This would be the best test of the entire fan circuit.
John, are you sure they didn't come on? Did you get out and listen for them or pop the hood and seem them going? On mine I can hear the fans lightly before it even gets up to operating temp (sticks right at 210 on the needle and stays there once warm). Fans run constantly when it's idling and warmed up as far as I can tell.
I'm pretty sure. I stopped once on the way up, popped the hood and took a look. Neither one was running. On the other hand, 225 was where it stopped. There was no reason for it not to get hotter, other than the fans were running.
So you were pulling enough weight up a steep enough grade to need to be in 4-LO? Would not be surprised to see 225 water & tranny temps.
I've had mine get up to about 240-245ish while towing a 17ft. trailer up hill... after that it seams like the fans kicked on at odd temps... i've heard them kick on when temps hit about 230-235. i took it to the dealer and they thought maybe it was the thermostat so they replaced that but that didn't really seam to fix it. they said the fans are set to kick on at 230, and that they were working fine. it usually runs at 210, but it will go up to 225-230 quite often and then drop back down pretty quick. it seams fine when i first start driving but after about 15-20 mins of driving is when the temps start to fluxuate between 210-235ish. ohh yeah... this even happens while driving on flat freeways at about 65-70mph.
I think i'll try another dealer some time this week... i'll repost after i take it in... maybe we are having the same problem..
Also on my truck at least, there are two separate temperature sensors. One for the computer, and another for the instrument cluster temp gauge.
In the past on various vehicles, I have had these not read the correct temperature (then replaced it), so I would not be surprised if one sensor was reading a bit different from the other.
I don't know about your specific truck though. Might ask at the dealer if there are two sensors or one for both functions????
Anyone here know?
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
