Steering Shake With Oversize Tires
I just installed 20 wheels and tires on 2005 sierra 1500 2wd crew cab and on uneven services and rough roads the steering wants to jerk out of my hand. I know there are steering stabilizers for 4wd models but not offered in 2wd models. Can anyone help to resolve this problem?
It seems that most people who put on aftermarket wheels have a vibration issue. There are little washers on a couple of the wheels studs. I'll bet if you remove those the vibration will go away. I'm sure others will chime in also.
Either a balance issue or something else is wrong. You shouldn't need a steering stabilizer for 20" tires. They are to help with bump steer, not to mask another issue.
Did you install new wheels too?... If so, are they hub centric or lug centric wheels. Also another issue that could be getting worsened by the larger rims. As mentioned above, GM uses lock washers to hold on the drums/rotors during assembly. If you have lug centric wheels, then this clip could be causing your problem.
If you have a trusted frontend shop, take it there and have them check out the front suspension (ball joints, tie rod ends, pitman arm, steering box, etc., and especially the idler arm.
Chuck
Chuck
I had the truck checked and everything is okay. This year model truck has an rack n pinion steering and I don't think they offer any sterring dampners for this application. Is there anything out there to damping the steering so I don't feel so much of the road?
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
    • Open the driver's door jamb.  What do the cold tire PSI ratings on the tire placard show?   I'm not saying to run it to those numbers, but I would like to know what it says.
