Erratic Speedometer/transmission Stuck In 2nd Gear.
freeloader
Which wiring diagrams are you using? GM factory?
In the back of my 92 factory wiring diagram manual is a list of connectors.
I was using the ones available online from our local library but they show no connectors.
http://www.gm-trucks.com/forums/index.php?showtopic=98594
I've been having a problem with my speedometer acting up and my transmission sometimes gets stuck in 2nd gear. BTW, it's
a 1994 GMC Sierra with a 4.3L gas engine. I've read somewhere about changing connector 240 under the dash. I can't find
that connector anywhere in wiring diagrams. Any help would be greatly appreciated.
I have had that same problem before, and it ended up being the vehicle speed sensor...
Been there too. VSS fixed it.
