Drive Train "clanking"
DTS419
When I put my truck in reverse (foot on or off brake), I hear a distinctive "clank" noise. It sounds like it's coming from the rear of the truck, but hard to say for sure. I also notice the same noise when I am coasting to a stop with my foot on the break and the truck is downshifting. And sometimes, I hear the same noise when the truck is up shifting if I take my foot off the gas just before the shift. Otherwise, the tranny shifts fine, no slipping or hard shifts, just this audible clanking sound that seems to be happening when the drive train is not loaded in forward motion- like there is some slack somewhere. Am I just hearing the notorious G80 rear, could it be a bad U-joint, or is this a warning sign of a coming tranny or transfer case problem? Or is this noise just normal for a truck with heavy duty off road suspension and drive train? And is there anything that can be done about it if it's nothing serious?
Well I would certainly have your U-joints checked just to be safe.
As they say, if your "front" U-joint fails, you may go "pole vaulting" into the toolies...
Grease your slip yoke and see if you still have the clank....
What kind of grease? Do I need to pull the drive shaft off to do that?
Wheel bearing grease will work, yes....the search function might also yield other tips or solutions if that turns out not to be the problem.
After doing some searching, I'm pretty sure my next step in the troubleshooting process should be to grease the yoke...
I know what the slip yoke is and how to get it off, but before I go getting grease somewhere it doesn't belong, can someone elaborate on exactly where to put the grease, what kind of grease, and how much?
Am I greasing inside the yoke, am I greasing the male splines inside the end of the transfer case where the yoke goes in, or am I greasing the outside of the yoke shaft...?
How do I prevent from contaminating the transfer case fluid with grease?
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
