Different Octane Gas
I was just wondering if you use a higher octane gas in a gm vehicle with piston slap will it help it or is it worse for the engine. GM told me that i should stick with the lowest octane or the highest and not to go with the medium grade. so i guess what im asking is will a higher or lower grade gas help piston slap in my engine. Thanks for the response.
if youre knocking you can try a tank of high octane gas to see if it helps. I think them not recommending medium grade is BS
i only experience knocking for 15-20 seconds on very cold mornings on initial startup then its gone but i cant really tell because i start it with my remote start but thanks zz327 ill have to try it come next winter. has anyone else experienced a difference when using different octane's
For the piston slap issue you are describing you will not see any improvement with higher octane.
If you are experience detonation under a load then you may need to step up to a higher grade. But unless your truck actually calls for high octane there really is no reason to run it. If you are experiencing detonation (and your doesn't call for 91+) then there is a problem somewhere (carbon build up, sensor problem, bad gas, etc)
+1
my truck used to make noise, at 160,000+ it is quite. I started using chevron techron injection cleaner. I was putting two bottles in at each fill up for a little while then just started doing it on oil changes after it got quiet. after a year it is still quiet, no more slap.
  • 4 weeks later...
Actually, you were experiencing pre-ignition due to the carbon build up. It actually pre-ignites the mixture before the spark plug, so it actually lights off before it is supposed to. This causes a higher pressure than normal as the piston comes to the top of the compression stroke, causing the noise perceived as piston slap. You did exactly what you should have, in that the the additives you put into your tank cleaned up the excess carbon, eliminating the hot spots causing the pre-ignition.
Detonation is usually under full throttle and is very audible and VERY destructive. It is more of an un-controlled burn, with VERY high pressures.
Back to the original question in the thread, the higher octane fuel actually just burns slower than the lower octane variety. This slows combustion and prevents the detonation under full throttle. This is definitely more evident when an engine is under more load, say pulling a trailer or with more advanced ignition timing. Whoever told you not to run the mid-grade was full of zhit.
Hope this helps...... :thumbs:
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
