Bilstein Leveling Kit On! Will 33x12.50 Fit?
Just got my Bilstein Leveling kit installed yesterday. Installation was pretty straight forward on my 09 LTZ CC. I want to retain my Z-71 wheels but want to run the Toyo Open Country MT 33x12.50R18. Will these fit on the stock wheels and will they rub? Is a 33x11.50 the widest one can go on stock wheels?
rub for sure, I would go with less width on the tire, 12.5 is too wide without more lift.
Did you set the Bilsteins to their highest setting? Pics?
How do you like the ride? Is it stiffer? I am asking because I too have the Z71 package and was wondering if the bilsteins are worth getting. I already have a leveling kit so the ride is really the determining factor.
Louie,
the ride is slightly firmer, but the bouncy, loose feel at freeway speeds is gone. Best damn thing I've done for this truck. Worth getting? Hell yes! The truck feels like it's glued to the road and the ride gives a feeling of confidence that the truck is fully under control at freeway speeds while going over the whoop-tee-doos of the LA freeways. Prior to the shock installations, the truck felt like it was on the edge of being out of control at normal freeway speeds when going over those overpass bumps, etc.. ....and my truck was brand new with the largest shock/spring package.
Chuck.
I will take some pictures tomorrow for yall! As for the ride it is incredible. I too like the extra stiffness of the front suspension. I went on the highest setting on the fronts and it is dead on level. For those planning on doing it, you will need to buy a Lisle shock installation tool so you can tighten the shock stud nut to 19ft lbs while keeping the shaft from spinning. I guess the only thing left of my Z-71 is the skid plate and sway bars since I ditched the shocks and the stickers! As for the tires I decided to play it safe and went with a set of BFG All Terrains in a 285/65R18. They look nice and ride nice to boot
D
Would you mind posting a few pics? Any rubbing lock-to-lock?
When you say you installed the strut at the top position, how much lift did that give you in the front?
Also, what tool did you use for compressing the springs?
  • 3 weeks later...
i have a set of the 285 BFG's in 18's sitting behind my shop. I had to ditch them because they ride so damn stiff. They are E rated and weigh like 80#'s each, where the stockers are like 42#'s. Just a word of advice, if you like a good ride, they may not suit you. I aired mine down to 40 psi and they rode well but the mpg went south. I have some Cooper SST's now but they are louder than AT tires, I like but the wife hates( I say I like, the radio is blaring if I'm riding so I dont notice).
Plus the weight of those monsters killed my haul ass even after I reprog'ed with my Edge.
ditch that crappy edge (trust me I had one) and get a Black Bear Tune.
Anyone have pics of installed Bilstein leveling shocks?
How much is shock tool, or can it be rented?
Do you think 295/65R18 on the stock all terrain wheels will fit?
I will take some pictures tomorrow for yall! D
How bout them pics? Do you have to purchase the rears with the fronts? Is is recommended to replace the rears?
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
