Painted Bumper Cap
Hey Guys,
So I'm having a new lower Valance painted black professionally by a body shop as my old one that I painted 1.5 year ago is flaking really bad. I thought I'd have the bumper cap done at the same time and wondered if Matching it to the truck would look better than the black bottom.
I half assed a photoshop of the white let me know which you like better. I'm leaning towards black top black bottom but, just curious what everybody else thinks?
Evan
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
