Speakers /AMP
I have (2) MTX 8" subs in the MTX boxes for sale. This would be great for our S10 owners that want to add  some base to their system. I also have a Sony amp (I think 75watt) that was used with the sub's. I will consider selling in parts.  This equipment is left over from my last truck, need to get rid of it, I'm selling this stuff for CHEAP. e-mail me if interested  [email protected]
  • 3 weeks later...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
