Intersting Vid O Pos?
boosted475
I just made a video for this company. It's not a straight up commercial, they wanted something a little bit vague. Anyway, it seems like they are going to use it as I made it up on their page. But it's still a 1st version so I would like some input on what you think about it and what minor edits I can make to give it just slightly more of a commercial feel.
I know the girl isnt HOT, but at least she has big milk dispensers. Hahaha.
http://www.circuspop.com/adlandingpage.html
I have it posted on Youtube as well.
More pix of the giant OEM power steering rack? :thumbs:
