Sluggish Take Off
ednav75
I have 95 gmc k1500 z71 with 350 that is sluggish when you accelerate from stand still. It idles fine and runs good at other speeds. The exhaust has a strong odor that seems to start as the engine warms up and continues from then on. Has new cap, rotor, wires, plugs, air and fuel filter, ecm, and ignition switch. I have considered changing O2 sensor and checking the cat for blockage. Any advice would be appreciated.
Is the strong odor coming from the exhaust a rotten-egg type smell?
If it is, your cat(s) are done.
No, its smells like gas and gives you a headache pretty quick.
your running rich then, o2 sensors need to be replaced...otherwise you got leaky injectors
