Factory Remote Start
jpierce575
I am sure this has been covered before, but I searched and cannot find the answer for my truck, just for older ones.
I have a 2010 Silverado that I just purchased and part of the deal was for the dealer to install the remote start. My salesman is now telling me that the factory remote start cannot be installed if it was not ordered originally and he wants to install an aftermarket one, but he didn't tell me what one. What RPO codes do I need for them to be able to install the factory one? I read on here that I need AP8, which I do have, but the window sticker says nothing about remote start installed or ready or capable. Is this the only code I need or do I need anything else?
It is supposed to go in and get this done on Monday, so time is critical. Should I just let them install the aftermarket one or insist on factory if I have what is needed?
Thank you.
I have a 2010 Sierra. Like you, getting remote start added, was part of the deal. I had AP8 also and the dealer had no problem adding the factory remote start. :)
So is AP8 the only code I need? If so, I am going to insist that they install the factory one.
you may have to go for the 2 way remote start. Give the parts guy your vin and tell him you want to buy the gmaccessories remote start, he will find the one that fits.
So does anyone know if I get the factory one, whether I order it myself or they install it, does it come with just the two new remotes or is there a module that has to be plugged in somewhere? I know the dealer has to enable it in the computer, but I just wondered if there is an unused plug somewhere that I can point to and tell them it is already ready for remote start. As I said earlier, my salesman said if it was not ordered originally, it was not a feasable option because he said the wiring was not there.
You SHOULD get the factory one I'm 90% sure!!! All these trucks have the wire-harness/prep for the factory remote start, unless its a basic work truck model W/T. Dealer should have to add the receiver devise and give you the remote start key-fob. He is WRONG about having to install a after market one. If he still tells you this, I'd go to a different dealer. Hope this helps and that you get the factory remote start like you want. Anyhow, congrats on the new truck :):chevy::seeya:
Daniel
the part you need is # 17801236 this package has 2 remote start key fobs and the necessary start modual this will be installed by the service department the modual has a serial # that needs to be programmed from head office (GENERAL MOTORS) whole process is about an hour yes "insist that parts be installed or find another dearship"
That is the number that I thought should work. I guess I am going to have to cancel my appointment Monday and insist that it gets done the way I want. What I don't understand is that they are eating the cost of this install, and I was quoted $399.00 to install the one they are trying to talk me into, The factory one costs $195.00, plus about an hour for the install at $90.00, so that is $285.00 my cost that they have to absorb. Why in the world would they not do the cheaper one to begin with? I am sure the $285.00 that I would have to pay is considerably more that their cost.
Anyway, thanks for the info everyone. By the way, the truck is a 2010 Silverado LT Laser Blue Metalic Special edition. I know most of the aftermarket installers are reputable but I just don't want my NEW truck wiring harness hacked up yet to install something that was available from the factory.
just because a person works behind a parts counter or service desk doesn't mean they are aware of all the parts that fit a certain vehicle i asked the young fella at a dealership down in Newmarket if he knew what a "dic" was he said "no"!!!
I had the dealer install the gmaccessory remote start on my 2010 Sierra SL. They had to use the kit that came with the extended range antenna, and I got the 2 way one. The two way one only comes with one fob, but they simply redid the other two so they still worked to operate doors and horn. I work from home, so the only need for the remote start is at home, so that fob stays there all the time. I think the 2 way was about $20 more than the standard one, and gives you basically most of the info the DIC does, plus fuel level.
After some persistance, I was able to get the OEM remote start installed today.
because if there is a problem with the aftermarket starter its not there problem its yours. with the oem they have to warranty it like it came on the truck
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
