Check Engine Light Code P0449
07 tahoe 50,000 miles check engine light is on, autozone says code is P0449 this is what their ticket says:
The PCM has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid in the evaporative emission control system.
Definition:
EVAP (Evaporative Emission System) purge/vent solenoid circuit condition
Explanation:
The solenoids and system wiring are monitored for opens or shorts
Probable Causes
1- Purge or vent solenoids defective
2- Check connevtor and wiring
3- Fuel saturated vapor canister
4- Failed EVAP vent solenoid
anyone else had to deal with this, any info/help is appreciated.
  • 4 weeks later...
  • Replies 76
Definition:
Explanation:
Probable Causes
Hey HD,
My 2005 Silverado (70k miles) just popped this code over the weekend. I troubleshoot it down to the solenoid.
I am having trouble locating the replacement solenoid, though. I found a what looks likes a solenoid kit replacement, Part# 19152349(ACDelco Part#214-2082) but I can't confirm it's going to work on my truck.
How did you fare with your code? Did you get fixed?
Thanks, -Ed
i would like to know as well what the problem is... i have the obd2 scanner and this code pops up every 4 months or so... i just clear it till next time. lol. its a random code so it's hard to troubleshoot
Definition:
Explanation:
Probable Causes
Hey HD,
Thanks, -Ed
Which solenoid?? The purge or vent??
Definition:
Explanation:
Probable Causes
Hey HD,
Thanks, -Ed
The vent solenoid (I think). It's the solenoid on the canister. I have only been able to find the purge valve solenoid (AC Delco Part#214-1105) from a few parts catalogs.
Definition:
Explanation:
Probable Causes
Hey HD,
Thanks, -Ed
I believe gm has made a replacement part for the solenoid. I called about a month ago.
The parts guy told me $184, wow. I think this is a very common problem. I have not fixed mine yet. 2003 silverado.
just got this code in my 2007 classic w/ 13,000 miles. i think my truck was made on a friday. chrome flaking off wheels, windshield fluid resivior leaks, steering shaft needs grease, squeek in rear they cant find....
Hey HD,
Thanks, -Ed
I ordered the solenoid replacement kit (the AC Delco PN 214-2082) this week and it was $88 with shipping. I received it on Thursday. I am going to install it tomorrow. The install requires adding some additional hose tubing. I'll post the details after I replace the part.
Attached are some pictures and details and information on the install of this kit. The install took about 30 mins total.
EVAP_Vent_Vale_Solenoid_Replacement.PDF
  • 4 weeks later...
Thanks for the detailed write up Ed!
My configuration seems to be a little different. I have an '04 Long Bed Regular cab. My Evap Vent Vent Valve is located above the front outboard side of the tank. The hard hose going to the vent valve actually routes over the tank. The hard hose is secured over the tank with plastic clips that are difficult to see.
I was wondering about a couple things.
- Is there a trick to removing the hard hose from the tank side?
- What is the trick to undo those big clips that secure the hard hose over the tank?
Thanks....
  • 4 weeks later...
Just back from Service where they quoted me $320.40 to replace the Evaporative vent solenoid on my '05 Sierra Denali, $197 was the parts price. Anybody know "HOW" to replace this part? (Do I have to drop the tank?) Can't afford $300 in this economy so it's DIY time.
Omer ([email protected])
Definition:
Explanation:
Probable Causes
  • 1 month later...
Thank you
Ed8675309
The pdf file is perfect-------- the chev dealer where truck was bought wanted $543.66, I was 63 miles out of warenty.
I bought the replacement part gmdirect 19152349 for $74. as you know the parts look completely diferent from OMD.
your pictures of the replacement was extremely helpful to me, again thanks
steve ryan
  • 4 weeks later...
I have an 05 1500 crewcab with the engin light comes on and off. I did a diagnostic through on-star and they tell me that its an emission failure. I have replaced the gas cap and the light went out, but came on shortly after. I filled my gas tank up and it went out shortly after that, but came back on a few moments later. Is this something that someone is familure with this???
  • 1 month later...
The PDF that ED created is very clear and concise. I recent got hit with this code and I will be attempting to resolve this weekend. I will post outcome.
Once again, thanks Ed.
    LCH14
    LCH14
  • Who's Online   5 Members, 0 Anonymous, 840 Guests (See full list)
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
