Fog lights question
What do you have to do to have fog lights for a GMC Sierra that has blanks in the holes and no fog light symbol on the dash knob? Is the harness there ??? Do you have to replace the harness and dash knob ?? Is there a plug-n-play out there for this mod???
  • Replies 31
I had to swap plugs on the dash and add a additional harness.
That was on a silverado though. Don't see how it would be much different
  • 4 months later...
Yes they are 22902334. & 22902335 the part numbers are for a 2014 GMC Sierra 1500
I know where they have some new take offs if your in the market.
My information leads me that it may be very difficult to install factory Fogs on a 2014 GMC Sierra or 2015.
Okay ,
what I mean is I want to install a factory system on my 2014 GMC Sierra 1500. At this time I have a factory Delete.
My searching brought me to find out I can put in the Bezels , lamps plus the bulbs.
Next I was going to get factory wiring and a factory switch.
I was told that I could never get them working because the lighting now goes through the BCM.
They'res a code needed for them to work properly. I figure now I can hook them up to my crappy halogen wires
With a relay. If one wants to use a toggle switch that would work too. I can't see at night with these crappy
Head lights. If some one could lead me in the right direction or has the lens forsale I'm looking for Them .
From there I will figure out what to do. I can't afford D2 LED lights and brackets.
Thank You,
I hope I'm wrong .
I'm in on this bandwagon too... didn't think I would miss the fogs from my old truck but I do. I have a '14 Sierra SLE with blanks in the bumper... I'm wanting to put in stock Bezels and stock switch. May go with some aftermarket fogs lights though. If I get the parts in this post will I be good to go? I know I will probably need a reflash for the switch to work, right?
You're going to spend a lot to get the OEM fogs which won't do squat to help you see. Guys that have them either never use them or swap them out for a light that puts out enough light to be useful.
For what this will cost you. Either a HID kit in your OEM projectors or a HID projector retrofit will eliminate the need for any additional lighting and will be more useful for real driving.
As spurshot noted,mayby you should look for thread on this site about installing led fog lights with a remote switch system....look up infintyoff road. A member of this site " All Terrain" will guide you from there.I ordered stuff from them and I live in Canada...the best shipping from the US I've ever got.
But check out thread about LED lights if it's your thing, no harm done to read thread......
GH
I've already made the emotional committment to HID in the OEM projectors, that's going to happen within the month. Just haven't decided on which HID's. Maybe I'll start their and worry about the fogs later.
I wanted to order an HID Kit to replace the worst halogen light bulbs ever put in
To a vehicle a 2014 GMC Sierra 1500 5.3L
My answer was they won't work properly with out a canceling resistor.
They will go blinking there way to death. Or not work at all.
Then I read that Gmc put in a crappy reflective headlight lens and the Hid's would not be as bright as the should be. It's a mess. They should have taped flash lights in there it would have come out better.
How could a number One truck in my eyes truck start pulling cheap tricks like halogen lights in the first place.
In this day and age? It's not like I bought a Dodge . Oh wait all the Dodge trucks have Hid Head lamps.
I broke my own rule not to buy the first year redesign.
First, you guys that can't afford hundreds of dollars for d2 lights are probably going to end up on a more practical path anyway. D2 lights, even the DOT approved ones, will likely be too powerful to use in areas with oncoming traffic. A good set of low beam lights is the first need, IMO.
There are at least a couple inexpensive options. An inexpensive HID kit like the DDM, or a upgrade of the OEM 9012 HIR halogen bulb to the 9011, which is about a 25% bump.
  • 3 weeks later...
Yes I just purchased them for my 2014 GMC Sierra.
If your still interested let me know and I will post them tomorrow.
I remove the fog deletes on both sides in about 10 minutes.
There are some plastic spring clips and four bolts on each side . Use a 7mm wrench swivel type ratcheting Specially when you install the new bezels
. I am just trying to figure where I will wire the fogs . I would like to make it clean as possible.
I have to run new wires . There is no wire looms from the factory.
I was hoping to run them to a new switch from GM parts.
I don't know if it's possible to do that. The new light switch may be
Enclosed . Any one know if that is possible?
Thanks
3 weeks old 1500 Denali. I think these fog lights are pretty decent. I have not looked to see what wattage or if they are
quartz or just incandesent bulbs. Would like to know if higher wattage or LEDs are available?
  • 11 months later...
I know this is an old post, but does anyone know of an OEM wirining harness for fog lights on a GMC Sierra 2014? I've looked on gmupfitter and found nothing. I'm surprised no one has made one yet
    KJEK
    KJEK
  • Who's Online   2 Members, 0 Anonymous, 461 Guests (See full list)
