4l80e Flush Help!
Which ls the easiest line to remove for extracting the fluid? I removed the pan and installed a new filter and put 5 QTS back in the pan. I have 12 additional QTS to use to "flush" everything else out but the Amsoil instructions have me a bit confused. They say to remove the cooler LINES, why would you want to remove both? Am I missing something?
You only need to remove one cooler line, preferably the one from the trans so you can put a hose on the end of it.
DEWFPO
DEWFPO,
Thankyou for the quick response. That's what I was thinking. I think the return line is the one closer to the rear of the truck, is that correct?
Thank you
Todd
