Nnbs Removing Just The Rear Blocks For Semi-leveling
I measured the front and the rear spacing of the tires to fenders and there is exactly a 2" difference. If I remove just the blocks out of the rear it will give me approx a 1" rake. Is there any down fall to doing this. I thought about installing a 1.5 lift kit for the front but I am then looking at the expense of an alignment.
  • 3 months later...
don't reuse U-bolts.
I want to do the same thing here...are you saying don't reuse the U-bolts that are on the truck right now if I remove the block? If I don't need to reuse the u-bolts, do you simply replace the ones on the truck right now with an aftermarket bolt or the identical factory bolt....THANKS IN ADVANCE.
I was told not to reuse u-bolts because of all the torque used to tighten them. Shorter ones can be had at any parts store.
I've heard a lot of people say "do not reuse the Ubolts" but the OEM Ubolts are superior to the auto part store chinese cheapos. I would have no problem reusing them if they have enough thread to be tightened properly (not sure if they are or not). Just bring them up to tight and then torque them. I've seen shops reuse them many times when replacing leaf springs... I can't see any difference. :)
You're not supposed to re-use U-bolts because they're torqued to around 90% yield strength of the material. It has nothing to do with quality, it has to do with their design.
Bolts do a lot more than just "hold" stuff together by "squeezing"... there's a lot of other design aspects involved. Some bolts even act as springs... although the deflection is not visible with the human eye.
A lot of people don't know this and improperly re-use U-bolts. Most good mechanics know that they're not supposed to reuse them but dont know exactly why; so they say the same thing you did, "i dont see what the difference is", and put them back on.
Well... I understand what you are saying and while that sounds good, I'd have to see some specs to believe that they are actually that closely designed and built to such strict tolerances. I've never seen or heard of one failing and I know some pretty high end shops that reuse them regularly.
I understand what you are saying from an engineering standpoint.
See the links in my other post.
It's not that they're built to some super tight tolerances. Their torque value is such that it makes the material deform to acquire proper clamping force.
Just because you haven't heard of one failing doesn't mean that you should ignore proper installation. $.02
Edit: I also know a lot of high end shops and ASE Master techs who dont use a torque stick or torque wrench when putting wheels back on. Doesn't make it right...
PROPER INSTALLATION!
A lot of this is opinion and covering of ass. In this day of frivolous lawsuit after frivolous lawsuit, most companies "recommend" replacing anything you touch to get to the part you are replacing all in the name of "safety". Even people selling these things include statements like "should be replaced" "recommended replacement" etc in their instructions. I guess we can agree to disagree a bit here. I'd reuse mine in a heartbeat if I were just removing the block.
Don't know how else to explain it Jim... it's not CYA, it's inherent to design.
It's just like how you're not supposed to re-use bolts with thread-lock... they're 1 time use (unless its a type of thread-lock that you can reapply).
I'm not stating opinion.. im stating design fact.
You don't hear them failing all the time because engineers have to account for expected negligence and therefore we design "safety factors" into every system (this also accounts for material inconsistencies as well as other influences such as degradation with time/environment).
    250.3k
    user087
    user087
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
