Temp Valve Actuator Removal Replacement. 07 And Up
ONEDSOB
How to Remove and Replace the Temp Valve Actuator (Blend Door Actuator)Part Number 15887320.
Here is how you do it....
First Pull the 3 HVAC Fuses from the Fuse Box located under the hood. They are all 10 amp Fuses, #40 #50 and #57
These are all the tools necessary to do the job.
1 Screw Driver
2 90 degree adapter
3 #15 and #20 Torque Tip
4 7mm Nut Driver
5 New Temp Valve Actuator
The Temp Valve Actuator is item Number 9
The access is through the upper and lower Glove Box.
To access this area, you need to open the Lower Glove Box all the way by pushing the release mechanism on the right side of the Glove Box.
Then Remove the Upper Glove Box by first removing the lower trim panel, it just pulls off.
Then Remove the 4 Screws that hold the Upper Glove Box in place, then Pull the Glove Box out.
This is the Temp Valve Actuator after the removal and replacement. But this Video shows you where it is located as well as how it is supposed to work.
This is what it looks like with the Temp Valve Actuator removed.
After you are done Replacing the Temp Valve Actuator, reinstall the 3 HVAC fuses that were previously removed into the Fuse Panel under the hood.
Then Start the Truck, but do not touch the temp controls for at least a minute.
Verify your Temp Valve Actuator is working properly and Close the Accessed Area.
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
