35x12.50x18 Help
So guys, i seen a cc nnbs silverado z71 with only a leveling kit last night. it had 35x12.50/18 tires on it, with no cutting showing from the side view. how did he fit 35" tires in there? i know there are others and i'm about to purchase tires. i want to fit 35" tires because that's what ford's run and i dont want to be any smaller wether it's 2" or more. how much of a hassle is it to get them to fit if you got a cc z71 sierra with a 2.25" readylift on it? help
did it have stock wheels or aftermarket?
I had to trim A LOT to get my 305/55/20s to fit... and you can't tell from the side. actually, you can't even tell that I trimmed by looking in the wheel well unless you have another truck there to compare it to.
You WILL need to trim metal.. and i bet the tires still rub (at least the frame/sway bar with stock wheels). Remember, some people will put up with some rubbing just for the sake of running big tires... are you one of those people?
yeah. I rubbing isn't as bad as everyone makes it to be. Tires rubbed on my f-150 for 3 years and 50,000 miles and it ran fine and never had any problems out of it. They rubbed the paint off of the frame where it touched but why does that matter? It doesn't. But anyways, you may be right, I may have not spotted the trimming. Where all will they rub? he had 35x12.50x18 pro comp xtreme all terrains on stock wheels but i'm thinking about getting after market wheels with my tires. did you trim metal like you stated above? and trimming isn't bad but i don't want to have to beat the fender wheels out because this is a new 2010 and my dad wouldn't approve of any of this but it's whatever. a lot of the farmers around here do whatever it takes to run what they want and I have the same mentality
Maybe try some 34" tires that are pretty narrow, so you just have to cut some plastic and hopefully not metal? The width and setting them out further are the two biggest factors of how bad it's going to be.
Hey matt, what kind of trimming do you think I would need to do for 35x12.5's on a 18x8 4.7" backspacing on 7.5" of lift?
wow, interesting question!
an 8" wide wheel with 4.7" backspace is like running a 9" wide wheel with 5.7" backspace in terms of fitment with the fenders.... based on that, you should be pretty good running 35x12.5s especially with 7.5"
sorry it took so long... i didnt see your question earlier
Awesome thanks for the reply. I am wanting to avoid as much trimming as possible, I would consider putting in a body lift to do that if neccessary, but am hesitant because I still want max payload capability.
The guy (owner I think) at Performance Offroad on South Stadium, down by the softball complex in Jonesboro, says he can cut your fenders and reshape the wheel liners to fit 35's with stock sized wheels for $150. I saw the work he did on his own truck (Ford), and it looked amazingly clean.
You really need to trade me those 18's for my 20's, while we're on the subject :thumbs:
Actually, that was with a 3" level, not sure about the 2.25"... My bad.
yeah i'm friends with the owner of russells truck accessories son. he said they've trimmed 2 new body style(07-10) gm trucks to fit 35" tires. i really wanna run 35"s though. and I want your 20"s but it'll be weird because they no longer put them on the 2010's and thats what mine is haha and is that performance offroad place still open? it appeared empty a few days ago when i drove by it
anyone have any pics of 35s with just a leveling kit? have read about a few others doing this as well just not many pics around
I did a lot of bidness at Russell's when I had my Dodge... The other place moved farther South on Stadium, new building. They just reopened a couple of months ago.
You won't be weird if you get my 20's, you'll be unique...
I am deffinately interested in this as well. I really dont want to go 6", but if I have to I will. I would rather do a level and 35's...
Yeah there are pictures of a white sierra with 35" toyo mt's with just a leveling kit. look up "NorthFlaRedneck" he has one and it looks a ton better than many lifted trucks. and mike i'm the same as you, i don't want to lift and thats why i'm going to figure out how to fit 35" tires in there and hester thanks for the information i'm going to check their new shop out after i find it haha.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,829 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
