Ac Continously Runs...
webejpn
1999 Tahoe LS with 5.7
Just bought this truck and it's my first non-Jeep vehicle so I am a little lost on the mechanics of this truck.
I noticed with the AC controls switched to off and after driving short or long distance, i would get a puddle of water under front passanger tire and passanger rear corner near exhaust outlet.
I then noticed cold air blowing lightly from the front vents by the windshield with the controls still off. If i adjusted the warm/cold switch, the temp would change accordingly. With the system off, if i try changing the vent selection, nothing happens. So the temp control works all the time, the vent selector switch only works when the system is on and the off/low/med/etc switch does adjust the fan speed when its on, but appears it doesn't turn off the ac.
With the system off and truck running, the AC is engaged. I disconnected the plug on top of the ac pulley and it did in fact turn off the ac/clutch. I checked the 10amp fuse and that's good.
So is there a relay or something in the system, or how do i check if it's the controller head??
Thanks in advance guys!!
your big middle paragraph is as clear as mud Matt,
the control head is a module and may have code in it ,get it scanned/diag'd properly
looking at the data in the scanner is very helpfull to diag the motors that control the doors in the heater box
luck
Ok, let me try an rephrase it a bit more clearly.
With the truck running and the entire temp control unit switched to off, the AC clutch does not disengage and continues to blow cold air out of the defrost vents.
If I leave the fan speed knob on off (system shouldn't be on at all), but I adjust the temp knob in the middle, it will adjust the temperature.
If I leave the fan speed knob on off, but I adjust the vent selector knob on the right, it will not blow out any other vent but the defroster vents up by the windshield.
When I turn the fan speed knob on anything but off, the systems work correctly although the AC clutch from my knowledge shouldn't be engaging unless I select the AC button between the temp control and vent selector knobs.
Is that better?
Is that better?
Do you have it in the recirculate mode? If so the A/C is going to continue to run regardless if you have it selected or not. The airflow never stops completely even w/ the switch turned off....it's normal. Your other problem sounds like it could be caused by a bad actuator.
  • 1 month later...
nothing on scanner, zipppo.
here is a recap...
This is our tow vehicle that i bought used about 2 months ago. The AC worked fine when i bought it. About a month ago i was taking it to work in the early AM i noticed when the sun got just right, the vents had ice cold air coming out....kicker is the controls were all set to off.
So i looked under the hood, sure enough, the AC pump clutch was engaged with all the controls set to off. So i just unpluged the little wiring harness at the pump and the clutch disengaged.
So i ran a scanner, no errors/codes.
About 3 weeks ago we went to use it for camping and i plugged it back in so we would have ac for the ride. Noticed it wasn't blowing very cold at all, so i just left it run and rolled the windows down. About 30mins later a horrendous squealing was coming from the hood...thought i blew the damn header off icon_e_smile.gif As soon as i disconnected the ac pump it went away.
Makes me wonder if part of the problem is the low pressure switch is bad or has been bypassed
both of my current silverados blow air out of the vents even when its off but its not AC cool air. my old 99' GMT400 did it too. it might be normal.. are you sure its AC cold air blowing out?
had a similar issue with the recic door. Seemed to clear up when I had the rear done and the battery was disconnected. Try the reset steps for the HVAC system on this site, it may help. Also, make sure to remove the fuses as well when disconnecting the battery as this seems to help.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,532 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
