1999 Yukon Fuel Guage Shake?
HELP! My 1999 Yukon has a fuel guage that shakes? I have replaced the sending unit in the tank and check the ground connection (new connector) and I still have a wonky guage??? I have the guage cluster pulled and will be searching the local auto salvages for another. Has anyone seen this before? How did ya fix it??
Thanks in Advance
Freaker
Very true, but ussually the gauge will sit and shake back and forth, sometimes fast, sometimes not at all. My oil press' motor went bad on mine and it would shake like crazy sittin' at a red like.
The guage does shake back and forth like an electrical problem .... I assume the stepper motor can be replaced? I have the cluster out and apart but I can't see how to get the guage front off from the circuit board? No screws or clips to be seen??
OBS, right?
That was a stupid question, but I was hopeing you'd say no. On mine, which is a NBS(don't hurt me MATT) all I had to do was take the black plastic cover off the back, then lift the circuit board, turn the stepper motor and out it came. But, you'll have to pop the needle off with a fork, no need to mark its position if it's already a little shaky. Then once the mottor is all in, and everything but the needle is on, hook the cluster up, turn truck to run and push the needle on over the 0 position as that's where it sits when it's off.
Just picked up a used guage cluster at the auto salvage installing it after work today. I will let you know if your theories are correct?
Sorry ... installed new used cluster and it still shakes! ??????????????????
Next step check body to frame ground?
Any more suggestions anyone??
What??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????? This is impossible, I can't be wrong!! Does the volt gauge fluctuate any?
Nope! No Volt Guage movement .... What's the chances of getting a bad used cluster with the same problem? Pretty SLIM I would think?
I have a similar problem that started about a year ago ('99 OBS K1500 P/U). I've read about others having the same problem, so it's probably fairly common. My friend has the same issue in his 2001 Silverado. I haven't replaced anything because I've yet to find anyone with a definitive solution. Here's a video of what mine is doing:
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 733 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
