Adding Cruise To Nbs Truck
After reading divejoes threads about him adding the radio controls, I was wondering if I could add cruise control by buying a new wheel. If I pull the airbag on the current non-cruise wheel, will I be able to see right away wheter or not a connector for cruise control is there?
  • 2 months later...
  • Replies 49
just got finshed adding factory cruise to my 07 nbs sierra
here are the things needed
1. steering wheel with cruise buttons and wiring harness (no harness available yet)
2. clockspring that has steering wheel controls
install is easy no puller needed, remove air bag and covers over column
clockspring is connected from steering wheel harness,
and air bag wiring pigtail
install the new parts ,
the truck will be need to programmed at the dealer
they will need to call techline for a bcm recalibrate
please call you dealer for costs i estmate they would charge a hour at the current rate
the bcm gets reflashed and sir relearned,
then the cruise will function as factory with cluster indicator
but the switch backlights will still need to be wired
do this pull driver side dash fuse panel out
note the 2 amp swc bklt fuse is missing and no terminals for it,
the back side there are a brown and yellow wire at the top next to each other connect them together with a fuse pigtail
push the fuse panel back into place
there the lights should work and for radio controls too
please note there might be some build changes but my truck is early 07 and base model
reply if you have questions i will try to help as this is fresh in my head
Guest Riggs
i recently got cruise in my truck, after a throttle body switch and boy is it nice!!!!!!!
Isn't cruise pretty much standard anymore?
looks like its still not standard on base and wt trims
looks like that offends some people,
i will say the tundra has all your basic options standard
and if wasnt for my gm discount there would be a bed shakin' tundra in the driveway
unless you buy a real truck (titan , tundra) there standard
a real truck? :banghead:
update
base trucks do not have the bcm prewired
i checked the some trucks on the lot
mine is a crew wt i have the wiring to the bcm
im working on part numbers for the terminals needed
but it still can be done
so far i have 125.00 in the cruise add on
You hear that, Jeff?
unless you buy a real POS Wannabe truck (titan , tundra) there standard
Daddy, Alaska...what's the problem, looks about right to me. :banghead:
  • 2 months later...
update
Do you know the part # for the clockspring and where to get it? Thanks, Jason
PLEASE... What is the PT# for the clock Spring??? I have researched this and it was looking like i needed another harness as well....hell yea if i don't!!
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   3 Members, 0 Anonymous, 1,109 Guests (See full list)
