Radio Install Qustion
changed radio in my 88 to a after maket i was wondering on my new cd player what wire if any should i tap it for the ilumantor wire that comes off the cd player
If you hit up www.the12volt.com and search for your truck you'll find an explanation of what each wire does, if your illuminator wire isn't the same as the one that gets tapped into the accessory wire, then you'll want to have the illuminator go to the acc wire too (the one that only gets 12v when they key is turned)
Hope that helps!
Stu
Did you use a wiring harness? Is the wire coming from the CD player labeled as "Illumination" or "Dimmer?" If you used a wiring harness and the wire is labeled as Illumination, connect it to the solid orange wire coming off of the harness. If it's labeled as Dimmer, connect it to the orange wire with a white stripe.
If you didn't use a wiring harness, this should help: http://crutchfield.custhelp.com/cgi-bin/cr...amp;p_topview=1
yes its the solid orange wire comeing from radio into harness , then i comes out of harness but then were on truck do i hook the orange wire . and its labled Illumination also when units off i have no clock i was told its because i need to hook up that wire its on a kenwood kdc 4009 if i helps
So you didn't use a harness adapter and just cut off the factory plug? In that case, just use the Brown wire (NOT the same brown wire that goes to your left rear speaker).
sorry if im being confuseing its been a long day . no i did use a harness adapter but off the wireing harness is were the orange wire comes from for the cd player but you said just hook it to the brown wire ? thanks
Yeah, there should be another brown wire, but not the same brown wire that goes to one of your speakers.
Do you have a voltmeter? You might want to make sure that wire supplies 12 volts only when you turn on your lights.
i found a brown wire that gives power to my ash tray light . when lights are on so im gonna connect it to that . thanks thunder struck
With my Pioneer DEH-P3600 I couldn't ever get the illumination to work right. Even now I can't but the 04 has 2 illum wires to connect to on the harness. I guess I picked wrong.
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 858 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
