Better Lift Hight
better lift
51 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
please answer the poll and leave a comment saying why you picked that one and also pros and cons of the heights of the lifts and any pics you may have
I went with a 4" lift. If you go with a 6", you can't go over 25mph in 4wd because it vibrates bad. You can fix that by getting a longer front driveshaft (For Pro Comp its around $700 for it.) Also if you go higher up it can mess with the stabilatrak. Most 6" lifts you have to cut out your crossmember and with the majority of 3" lifts you don't.
I just realized you have an 04, I am just talking about the NBS. You won't have to worry about the stabilatrak.
3" will also still allow you to use parking ramps and fit into std garages.
Yea....well I already have trouble pulling into Sonic's with my truck.
  • 1 month later...
I would got with rough country suspension's 6", that is what i have on my truck and it requires no front drive shaft. I run my truck is 4wd at 4o mph and it doesnt vibrate at all....i know the pro comp lifts do, the the fabtech, rough coutnry and bds kits dont vibrate. Plus the rough country lift is the cheapest.
I'm leaning towards a 3in. I'm just curious, with a set of 33's or so, how high does the actual truck go(from floor to antenea)? My main concern is fitting in my garage, which is I think 83 inches high? does that sound right?
If your garage opening is that high, you will not have any problems fitting in the garage with that set up.
