Code Po 420
My 2003 silverado 2wd 4.8 L engine with 130,000 miles . It keeps getting code po 420.
Will I have to replace the cat., or could it be something else wrong.
thanks for the help.
We had a bad O2 sensor front 1 bank 1(front drivers side) and because of it we had to replace the Y pipe, fried the Cat(s), but thankfully that was covered under Federal Emissions Warranty.
You made need a Tech II to read the parameters.
Good Luck. Keep us posted.
  • 1 year later...
What kind of cat u use and did code went off?
P0420 is a Catalyst Efficiency code. With that many miles on it, I'd suspect a catalytic converter.
What is happening is the O2 sensors have similar readings. The converter is not working as efficiently as it should be.
What I have had to do in the past is replace the cat and all O2 sensors. No sense in installed old sensors on a new cat.
Darin is correct, but you should also have the vehicle diagnosed to make sure nothing else upstream of the cats and 02 sensors are causing the Cat and 02 Sensor to go out. Otherwise, your just throwing money away and the problem will reoccur.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
