Blackbear Tune For 8100
I have a 8100 and have been talking with Justin about tuning my truck. I was wondering if i just send him my pcm and let him tune if i have to do the crank relearn procedure? I dont mind doing without my truck for awhile.
If you are using your stock PCM, no you won't need the crank relearn.
Exactly...crank relearns only need to be done if the pcm came out of another vehicle
cool I'm in the process of getting my 8.1 cammed can blackbear make adjustments for my new cam with just sending him stock PCM or will I have to do the cable tune that blackbear sends to me to get info. Thanks for all your help!
Cable tune would be preferred in this case due to common fueling issues on the 8.1s
my local dealerships says they can put a mild cam in my truck without having to replace the push rods, rocker arms, etc. Is this the case, does it sound right? I'm spending quite a bit of money with them and don't really wanna have to open it back up in a year or two.
My cam is a "mild" cam and I upgraded my pushrods and springs. You might be ok, depending on the cam.
The best person to ask, would be a cam company. See what they suggest and as if you should be beefing up any other components.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
