Mast Cylinder Front
mhart
I don't know where you would get that information. It might say somewhere in a GM factory service manual or with installation instructions for a new master cylinder, but probably would just mention it in a diagram if at all. Or buried in the troubleshooting text in the factory service manual.
If you have a double fluid compartment master cylinder, I suppose you could try bleeding one of the front brakes a bit and see which compartment then has a lower fluid level. Then I would assume that the line under that compartment would be for that compartment?
