Email
JJP442
Hello People,
I'm new to this forum and have only posted once or twice.
Is there a way to be notified via email when someone replies to my topic or thread?
On other forums I belong to I have it setup that way but can't seem to find how to do it here.
Can it be done & how?
Thanks in advance,
John
Big john NYC :cheers:
Hello People,
Thanks in advance,
John
I think I found it in the control panel.
Hope it works.
Big John NYC
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 524 Guests (See full list)
