Help! Goosneck Hitch With Airbags Not Possible?!
So I just left my local camper supply store, and they informed me that I was not able to run airbags and a gooseneck hitch on a NNBS Sierra at the same time He then called Firestone and Airlift to ask them if they sold any special bracket for that particular application, but both of them said "No!". The way that the airbag bracket mounts (for those that are unfamiliar) is that it basically wraps the frame rail on both sides---using the holes previously occupied by the ABS sensor plugs to sandwich the frame. The gooseneck frame rail kit needs to sit on top of the exact location of where the airbag bracket is----and even uses the same frame holes to bolt up. Without some serious modification---welding, cutting, notching of the airbag bracket and the gooseneck rail kit---I don't see any other option. :rollin:
Has anybody had experience with this situation? Is there another style of gooseneck hitch that will work? I want to keep the bags on---because I use them much more than I would the gooseneck---but it looks like my only options would be AALeaf or Timbren bump stop replacements. Talk about pissed off!
Hmm, well that stinks, did you get your bags yet?, and installed, if you can't use them, PM I'd most likely take them off your hands
I'v heard good things about the Airlift Air Cell's, and that type of thing
Yeah I installed them last weekend and LOVE them....I had about 1500lbs of stuff in the bed this weekend doing some planting/fertilizing and I pumped them up to about 80PSI and it sat perfectly level...rode great too. And I even like leaving about 10PSI in them empty---I actually enjoy a slightly stiffer ride. Feels like a truck.
Firestone has a bag out now that mounts differently...actually bolts up to the axle instead of the leaf springs---they're offset a little bit. I'm starting to think that I must just leave it alone and buy a new 2500HD. I know, I know---a little overkill...but with the recent announcement of tax increases, I'm going to try and expense out another work truck to take the write off this year.
From what I've read---all be it on Dodge and Ford forums---the only way to do it is to take the bags off, install the gooseneck rail kits, then go back and drill new holes through the rail bracket AND the frame, put spacers in to compensate for the lift on the lower airbag bolt of the leaf spring bracket, and mount it up that way.
yeah faricating a new bracket is the only way to go. Try moutning the the gooseneck flip over unit and a fifth wheel hitch basically the same headaches.
I just can't believe that in ALL the research I did and people I talked to---that no one mentioned that little gem of info. I guess you live, you learn...
You are correct about the Firestone Ride Rite system. It mounts over the axle where the overload bumps go. You actually remove those bump stops and that is where the bag mounts. Would this work for you?
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
