Leveling Kit Claims?
I was wondering how is it that different companies that have the same amount of lift for their leveling kits can claim to fit different max tire size? For example a skykjacker 2" leveling kit spacers claim to fit a max of 285/70/17 = 32.7x11.2 tire and a Revtek 2" leveling kit spacers claims to fit a 33x12.50? From what I have been reading in this forum, a 33x12.50 will rub with just a leveling kit.
# 1 reason is sales. sales department knows that most people are *generally* stupid when it comes to this stuff so they can make any claim about tire fitment without the need to back it up.
#2 - do either of those manufacturers give wheel width/backspace details? The one kit might be claiming "33x12.5 on stock wheels" whereas the other kit might be claiming "285/70/17 with an 8" wide wheel and 5.5" backspace max". A stock 7" wide wheel with 6.0" backspace can squeeze some 33x12.5s with trimming on a 2" kit.... if the 33s run small. If they run true to size or oversized... you're SOL.
I see from your sig that you have 33" tires...what type of 3" lift do you have? did you have to do any trimming to fit those tires?
duno about ur nbs but a nnbs doesnt have a prayer of clearing 33 x 12.50s with a 2" leveling kit
He had to cut metal.
  • 2 months later...
I have a 2 in daystar kit on my with stock 17's and i can fit a 305/65/17(33X12.00x17) with no rubbing at all. I know with aftermarket wheels with negitive offset you can't get anything bigger than 295/70/17 on the truck.
I installed a CCM 2.5" leveling kit in addition to a Zone 1.5" body lift.
I am running Cooper STT's in LT305/60R18 (actually 32.64" x 12.09" on 9") on Moto Metal 18"x9" with a +18mm offset.
Absolutely no rubbing at all, even at full cock and tilt.
I don't believe you can get 33x12.50's with just a 2" leveling kit, unless you have a large + offset on the wheels (tuck them in) or you wanna cut a little.
dont even bother trying those tires with a leveling kit i have yet to seem em work on a nnbs. Generally you need about 4" of lift to completely clear 33x12.5 With a level kit u can fit them under there but they will rub when u turn, when u back up, and when ur off-camber. I tried it, it sucks, ended up with a suspension lift.
