Crank No Start Help Asap.....please!
Bustedknuckle
Hi all,
I have a 05 Silverado with a 4.8L short bed.
Well, a couple weeks ago, I was on the highway and gunned it.....at about 3000 rpm the engine bogged out. It didnt clear itself so I checked it out. I have good spark and air obviously so I deduced that it was fuel.
The other day while driving up the road she died completely on me. Had to have it towed to the house.
Not having the 450 for the part (fuel pump) I opted for a used one with 10k on it. Doing this by myself I had to drop the tank (was 3/4 full). I just installed the new/used one and it wont start (I can hear the pump powering up though). I checked the relay (swapped with a good one) and nothing. Also the potentiometer is bad as the gas gauge reads zero.
Now I am having to use a jump start to get any juice in the battery as I am afraid that I burned it up trying to start it (to get it out of the middle of the road). This wouldnt affect the starting that much would it?
I know fuel pressure is probably next but I don't have a gauge. What after that? I know all about the noid lights but if it don't start than they are of no use to me.
Please someone shed some light on this situation as I am broke as a joke and this is already costing me money I dont have. :(
Thanks in advance.
First replace the battery and check all the connections are nice and tight, especially the grounds.
Then Check fuel pressure first for the fueling issue.
Thanks, yeah just went and got a new battery.....nothing. Tried using some starter spray but to no avail.
Dont really have the money for a f/p tester but here we are......
Any other checks I could do in the meantime?
You could roll your engine over by hand and see if you are timed correctly, you may have jumped your timing.
You could have a clogged fuel filter, change it out and see what happens.
you really need a fuel pressure gauge to test properly, but I think you may have larger problems by the sounds of things.
You can probably get a loaner fuel pressure tester from a parts store.
Nytemare:
Pretty much everything from '04 and up has fuel filter as part of the pump in the tank, at least on the V-8s
Thanks for the input y'all. I'm going to pick up a tester from my Snap On guy or Autozone has em to borrow. Not today though I'm done......I don't have the energy to wrestle with that tank again.....on my back in the wet. (not that bad really if you have dont have a choice but believe me grab some buddies and pull the bed if possible.)
I'm hoping it's something stupid but I'm thinking that it has to do with a nasty clog somewhere.
First I need to exchange that pump, don't know if the pump itself is no good but the fuel level indicator is out of whack.....so that's the potentiometer. If that's bad then maybe..........
you should be able to bring your pump somewhere to have it tested, that will save you buying another one...your original one I mean
Thanks for all the ideas everyone, I have good F/P at the line, fuel pump is working, have good spark, MAF is clean as a whistle...........here it comes......
Injectors clogged.......
WTF man...Thats total BS
you must be :P:mad::mad::(:freak:
I would kill the cork sucking bastage that did that to my truck if I ever caught him.
Hope you have insurance to help you with this one man
That's what I can't figure out. I'm the nice guy. Who the hell knows, waiting on my claim to go through as far as insurance goes. $2100 bucks in damage.
And yeah I bought a locking gascap already.
well if you look like your pic in your avatar...who knows...it doesnt matter how nice you are....that's offensive man :mad::P:P:(:freak::P
How is Rollie Fingers offensive? :mad:
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 487 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
