Crankshaft Pulley
I just put new belts and tensioners on my truck. On the A/C belt the tensioner is working overtime (it moves quite a bit). I'm wondering if this isn't due possibly to a loose crankshaft pulley. When I see it turning it doesn't look "true". Does this happen? Is tightening it as easy as it looks? (just tightening the nut in the middle of the pulley)?
Your actually talking about the Harmonic Balancer. I doubt if it is loose. You can check it to be sure though. If you click the link I provided you can see how a HB is put together. If it really is not running true you may have a problem with the balancer
Found a thread that I had seen before that has a video of a member's HB running. You might read through it.
http://www.gm-trucks.com/forums/index.php?showtopic=100613
With the age and mileage of your truck, I'd venture a guess that the tensioner is probably bad. I had a tensioner go bad on an S10 Blazer I had several years back with the 4.3L Vortec, and it exhibited similar symptoms. That's where I'd look first, as it's a far cheaper fix than a balancer issue, and a more common wear item.
This (seemingly) excessive tensioner movement IS on the new tensioner. Good to know about the harmonic balancer, this is something I never was even aware of (that it even existed). From the other threads listed I guess I will just leave mine alone (the last belt made it 120k without a failure, with new tensioners and idler pulley the new ones should also I reckon). Thanks for the info.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
