Another Tire Size Question
What would the largest tire be I could put on stock 18" rims with no lift on truck that would not cause any rubbing issues? Would like to go a little taller if possible but not interested in lift or leveling.
Thanks
I put a set of 275 65's on and there are no issues. According to my gps, it is about half a needle off the speedometer. I think that might be the tires im going to put on this fall.
i have LT275/65-18 C on my truck in a Cooper Discoverer STT and like them very well. a true truck tire. if you are not into a full MT you might try the Cooper Discoverer ST(not STT), as it is a little milder and more road friendly(noise). i have had sets of both tires and prefer the MT for looks and i also offroad alot and they seem to work well on the farm. C range not too rough of a ride but still pretty good sidewall and load capacity. goodyear silent armor are cool but they are shallow grips and i want some LUGS! My tires DO rub a little on the passenger side on full left turns, dont know why but it hasnt torn up anything. i bet you could fit a 275/70-18, may require an inch or so clearance cutting here and there.
Anyone else have a hard time finding a good selection of tires that will fit on these 18 inch rims? I really like the look of the 18's but I'm tempted to get something else just to have more tire options...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
