What Do These Chevy Rims Fit?
nummy
Hi Ive got these rims and I would like to sell them. But I want to be fair to all by knowing what years and models Chevy truck they will fit
Thanks
... I agree... all 16 inch diameter 6-bolt, Sierra's, Silverado ( & Cheyenne), Tahoe, Yukon ,etc... with 4WD
... they are likely a 7" wide rim for the standard size 245/75R16 or the 265/75R16 size tire
... as far as I am aware... the only GM 16" 6-bolts that they will not fit are the LD 3/4Ton 2WD ... like mine!!!
Those were on many of the 88-98 style Z71 and 91 up 4x4 Suburbans. The exposed "lug" centercap makes it about 96 or older. Later ones had smooth centercaps but used the same wheel.
Should fit all 4x4 Silverado's and Sierra's from 88 to 99. I'm sure more people will chime in to correct me if I'm wrong.
Bingo! Those are off of a 88-99 model Z-71 (when all Z-71's were 4WD). I had a set on my 97 Z-71. They will also fit a 00-present 1/2 ton PU, Tahoe, or Burb.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
