2007 Sierra Slt With Hard Shift...
joe_black
I have a 07 Sierra SLT 2wd that has started to exhibit hard shifting from 1-2 and 2-3. It is enough to feel a a jerk and I thought it was weird. The fluid looks great and the truck has about 66k on it.. Yeah, 66k.. LOL... The 1-2 shift is more jerky than the 2-3rd shift and the rest of the gears are ok and it is ok while down shifting.
Let me know what you think..
Thanks
Did you just buy it, or did you buy it new?
Was thinking the same as you I'll bet....does it have a shift kit or vette servos
Yep, or a tune?
I bought it used... I got a great deal on it and I couldn't pass it up. :loser:
I really don't know how to tell, I went to the dash and reset all the factory settings and i hooked my scanner up and reset the ecu. I honestly have no idea how to check the program on the ecm or tcm....
Do people usually install shift kits and fool with the 5.3 2wd Sierra???
Custom tuning and Vette Servos are very popular mods.
Really? The truck was stock or appeared to be stock when I bought it...
One thing in know is that it will move out of 1st and 2nd when I give it a little gas, I mean little gas. Also if i baby it in ist and second it is jerky but if i give it a little more gas it will be a lot smoother.... I just don’t always need to accelerate that hard, and try to cruise at times to save gas.... It usually shifts around 2k in those gears also, is that normal?
Is there any way to tell???
There is really no way to tell if it has a shift kit or corvette servos without opening up the trans or servo housing. But from the sound of things it has one or the other.
As for a tune you can get the ECM re-flashed to a stock tune.
Not if it's locked.
Not if it's locked.
To answer everyone’s questions and comments....
I bought it from a Nissan Dealership.
I just had the axle lubed at a GMC store and they said nothing.. I asked if its normal and they said it was for some models. I am out of warranty so I, assume they would have said there is a problem since they can cash in.
I was just wondering if there was an easy way to detect without tearing things apart, or a simple way to check thru the cluster, or to look at the ecm for a chip or sticker.
Or flat out my tranny is fu#%ed up. :loser:
Thanks for everyone’s help, and if you all have any more ideas lmk...
There are no more chips.
There may be a sticker on the ECM, but probably not.
There is nothing on the cluster to look at your ECM tune....just operating parameters, like fuel economy trans temp...etc.
Gotcha,
I asked because on my super duty I could look at my mpg and is was high like 26 mpg and I knew it was lying and my tune was active. Also, i would dump tons of smoke.
I was hoping there are some tell tell signs... I'll have it scoped and the tcm and ecu checked.
Take it to a independent trans shop professional (not a chain store shop) and see if he will drive it for an evaluation. A trans pro will know more than a dealer about common trans problems etc.
That's what I would do.
You can see if the vehicle exceeds 100mph since the first thing most people change when they tune. If you don't feel safe doing it on a public road you can put it on a dyno and you will now how much power you have too. Of course if they just did a vette servo the top speed limiter should still be in place.
    nolankd
    nolankd
  • Who's Online   4 Members, 0 Anonymous, 471 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
