Lq4 6.0 Swap On A 5speed 1500
Hey im in the market for a 1999-2006 sierra/silverado 1500 5 speed manual 4x4,Im plannng to swap in a lq4 or an lq9 from a totaled denali or escalade as soon as i find one . anyway what i want to ask is what parts do i require to swap from the 4.8 or 5.3 to the 6.0 also are there any drivetrain differences between the v6,4.8 and 5.3 because i searched and found out that they all use the same transmission (NV4500) and transfercase so if im gonna do an engine swap it might be cheaper to start with a v6 or a 4.8
thanks
You definitely don't want to start with a V6. You'd have to change motor mounts, PCM, wiring harnesses, etc. whereas when you start with a V8 it should just be a drop-in replacement re-using most of the original parts (even the accessory drive can be re-used). You WILL have to re-tune your PCM for the 6.0L engine's parameters, but past that you'd be in good shape.
To go to a 6.0 you would need to get a new trans. (4l80e) to handle the power. I'm also pretty sure you'd need a new transfer case. The rear ends are also different as the 2500's came with a 11.5" 14 bolt. Just some things to consider.
He wants a manual trans.... and the NV4500 should be able to handle it fine.
thanks
Both the 4.3 and 4.8 powered 1/2 tons that were available with a 5 speed originally used the NV 3500....... not the NV 4500 transmission. The 3500 is not an overly robust transmission so I would be careful with putting a lot of power to it........
Ahh I missed that. Reading comprehension > me.
thanks
i had a 2002 sierra single cab short box step side 4x4, came with 4.8 wtih the nv3500 5 speed. i blew that motor up and swapped it for a 6 litre lq4, port and polished heads and a mild cam. never had an issue with tranny really. just changed oil often and ALWAYS use the DELCO syncromesh, not the cheap stuff. at about 200k kms i sold her. had the 6 litre in it for 100k kms. when i sold her 2nd gear syncro was gettin pretty rough. but thats not the trannies fault lol. and thats with a hd sachs clutch, rear locker, 33 x 13.5's and a little bit more power than stock. the tranny never pooched out on me. over all i think you wil do fine with an nv3500 man, just servicce it and dont powershift every time your in it LOL
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
