Another Leveling Kit Question
I'm looking at the rough country 1.5-2.0 inch leveling kit... The truck is an 02' Silverado z71 with towing package. It does however have 180k on the clock. So I'm looking at the kit with the keys and the struts. My question is, are the Nitro 9000 struts any good that come with the kit? Or should i buy the torsion keys, then buy another brand of strut? Any suggestions? I just want the front to set level, not looking to lift with blocks in the back or anything. Thanks guys!
This is what I'm looking at. Keys w/struts kit. http://roughcountry.com/chevy_4wd_99-06_leveling_kit.html
You don't have struts.
Just crank the stock torsion bars up about 1.5" instead of wasting your money.
+1
If you do a search you'll find a ton of how to guides on doing this.
Sorry shocks, im used to messing with cars... Ive herd guys can get away with that, and then others that its hard on the front end... The truck is used as a work truck, and has 180k I figured that putting the shocks on also would be worth while just because of the age of the truck, while doing that figured i'd just add the leveling kit.
Edit: I have read that its fine, unless you crank over 1.5'' I may try going this route.. But I have going to replace shocks, any suggestions!?
