TRANS-X
MY TRUCK HAS QUITE A FEW MILES ON IT (192,00) SO I THOUGHT I'D GIVE THIS STUFF A TRY.  I LIKE IT! IT ACTUALLY FEELS LIKE IM GETTING A LITTLE MORE LOW END TORQUE FROM THE TRANSMISSION... MY TRUCK WILL "CHIRP" THE TIRES  ON HARD ACCELERATION WHEN SHIFTING FROM 2ND TO 3RD.
Is this a transmission fluid or additive? If so, how does it differ from B&M trick shift? My tranny shifts hard, but only occasionally chirps, I suspect it is the weight of the SUV on the rear tires as opposed to a pickup, combined with the wide tire and tread I'm using. 1-2 shifts feel like someone rearended me, but rarely a chirp.
It's very harsh, in fact I'm taking the 1-2 accumulator spacers out tomorrow (from the B&M transpack) and putting one spacer and a spring back in to soften it a little. (down to "heavy duty" mode from "competition mode"
I did notice the trick shift tightened it up quite a bit due to its lighter viscosity, but went back to dextron to try and tone it down a bit.
  • 4 months later...
:D FWIW, this product has been around at least 30 years. I've used it a lot in many different applications. Unlike most tranny additives, this one will not swell up the seals 'til they get so soft. they start to leak. I have also used this every time I installed a tranny kit regardless whether there had been a problem or not.
It will hel deglaze everything in the tranny which means better, more positive shifts. I don't know about the B&M product but this one in not marketed as a shift improver.
Hope that helps.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
