lazy4wd Posted December 8, 2009 Posted December 8, 2009 I have a '99 GMC Yukon 2wd and it came with the stock aluminum rims. My question is concerning a new wheel tire combo for winter. I want to get snow tires but put them on cheap steel rims, my concern it that maybe the heavier steel rims will adversely effect the handling and drive ability of the vehicle. Don't really want to break loose the summer tires from the alum rims. Any advice or tips of what or what not to do?
thearborbarber Posted December 8, 2009 Posted December 8, 2009 I've been running a steel wheel/winter tire combo for about 7 years on my last 3 trucks without any handling issues at all. I run snow tires on all 4 corners.
wages999 Posted December 8, 2009 Posted December 8, 2009 My truck has stock alloys and I run steel rims in the winter. When you lift the tires and rims, you really can't tell a difference in weight. I'm sure there is a difference, but you can't tell when driving.
lazy4wd Posted December 9, 2009 Author Posted December 9, 2009 thanks for the input. Does anyone know the bolt pattern of this truck? I has five Lugs and i think its either 5x5 or 5x5.5. have to be sure to get it right.
700 sportsman Posted December 9, 2009 Posted December 9, 2009 just go to tirerack.com or any other tire website, and they will have a chart to tell you what the proper pattern is
lazy4wd Posted December 11, 2009 Author Posted December 11, 2009 It a 5 x 127mm or just 5 x 5" thanks for the tip.
thearborbarber Posted December 11, 2009 Posted December 11, 2009 Thanks for the follow up info. It could help a member in the future doing a search.
