Colonel Truck Accessories
I had a bedliner put in my wife's 2001 Supercrew today. When they told me it was done, I looked at it and told them it was far from done. First off the nitwit installed it on top of the rubber bed mat that was in the truck. The sides of the bedliner were an inch from the bedside, they weren't tall enough to fit up under the factory Ford bedrail covers. The pillars back where the tailgate shuts were flopping loose. They got the bed mat out and put some screws in the sides to suck them out to the bedside. Eighth inch gap vertically on the sides where you can see the truck bed. I went to Colonel's web page and e-mailed them-returned undeliverable. Phoned, got Jim's Autoplex who said the Colonel hadn't been there in 4 years. I called the main office of Auto Trim Design, who put in in, and the guy apologized and ordered me a new Pendaliner. So Kudos for them. I wouldn't have paid them, but it was on a gift certificate I paid for a month ago for my wife. Then she gets in her truck tonite and a phone starts ringing. Her phone was shut off. Finally finds Auto Trim Design's phone under her seat! GOOD GRIEF!!!!
I am a little confused...was it a bad product or bad service/install?  Feel sorry for the guy trying to install it if the liner was that bad...
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,398 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
