Just Installed 3.5" Zone Combo Kit
I installed a 3.5" Zone combo kit on my truck last weekend. So far I like it but I'm just not sure if the front end is up too high now or not. I know the trucks pretty dirty but its all I have for now for pics. What do you guys think?
Looks good. kind of the same set up I have. I have the 2" rough country leveling kit and the zone 1.5" body lift. I think it is the perfect combination. Now get some 33" tires on it and it will be set!!!
I'd like to put some 33s on but I'm going to have to sell me old ones to get some cash towards the new ones, and then I'll also have to figure out which ones I want haha.
Also your pictures convinced me to get tow mirrors. I just bought some for $200 plus shipping and they are the heated, power, and led turnsignal. How hard was it to swap out the mirrors?
It does look like the front end is to high. It might be a illusion created by the wheel wells tho.
I think it would look better if you took the factory 1.5" blocks out of the rear and added some 3" blocks. It would only be a gain of 1.5" in the back but your front looks too level to me. Either way, some bigger tires are also a must.
and clean yoru wheel wells!
I think more than just the wheel wells need cleaning. The rear plastic ones were just installed a week ago!
I would love to put some better tires on it but its not in the budget right now. Anyone want my stockers? haha
I still may but blocks in the back as I do put my ATV in the back sometimes so I don't want it to sit too low in the rear, or maybe I'll put some air bags in.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
